compression problems
Discussion created by Guest on Jul 20, 2006
What are your rendering specs
e.g. frames per second, resolution and compression quality?
One thing I've seen happen (which is to say, I made it happen) is a rendering app shutting down building the queue for the output. It's got to store all of those frames before compressing them, so, if your vista is too big, you might be overshooting the 2Gb file limit. In that case, either adjust your size-quality expectations or try turning on the 3Gb switch. To that end, you might also want to try rendering to individual frames and then stitching them together using Camtasia or AfterEffects or something.
Good luck
