i just lately noticed that SW only uses one core when rebuilding the feature tree. i never noticed because i usually have no waiting time when rebuilding (our parts are not so complicated). Now i have a farely complicated part with a hundreds or so sheet metal bends and the rebuild takes a couple of minutes.
i read in the forum quite a bit and noticed that the issue is well-known. I'm now wondering if you are using 2 XEON CPUs, is the rebuild calculation split up on both CPUs or is SW using only one core of one CPU?
thanks for your help.
http://www.javelin-tech.com/main/support/pdf/hardware.pdf
