Propety Tab Builder List Changes to Text
Question asked by Jim Donnellon on Aug 30, 2010
Latest reply on Aug 30, 2010 by Scott McFadden
Our standard purchased part templete has a drop down list "yes" or "no" for downloaded part.  i made a property tab builder for purchased part with a list for downloaded part.  "yes" or "no".  when i use it, it seems fine if i fill it out thru the property tab builder.  i go to the file/properties pull down menu and it shows up.
if i use the property tab builder, then fill it out thru the file\properties pull down menu.  it seems to take untill i get out of properties and go back in, the field i just filled out is blank???
under both situation the property that should be a list type, is a text type. so under file/properties pull down menu, there is no longer a drop down list, like the property tab builder.
Can someone direct me to what i'm doing wrong?
Thanks!
