Hello everyone,
I help your help.
I had been trying for hours to use this function "AssemblyDoc:MirrorComponents" but i did not succeed.
Anyone knows how to use this function. My objective is to mirror the component(subassembly) in the assembly.
Am I in the right track?
Thanks in advance.
Kind regards,
Raymund
If you do not have a face/plane you want to mirror the component about, then you will need to Insert/Reference Geometry/Plane. From the assembly toolbar, click the arrow below "Linear Component Pattern" and select "Mirror Components". Select the Mirror Plane and select the Components to Mirror. Then select "Next" (right arrow) in the top of the Mirror Components Property Manager. Default is to create a copied component with identical geometry to the original. If you want an opposite hand version (true mirror copy) then select the "Create opposite hand version" icon in the bottom of the Mirror Component Property Manager. See Solidworks Help for more information and more detailed instructions. Search string "Create Mirror Component".
