11 Replies Latest reply on Jan 23, 2011 11:03 AM by Carter West
    Stumped!!  Should I use loft cut, split line ?? dunno
    Carter West
      Hello all
      I need to reverse a feature found in a 1/4 turn fastener.  I only need the sweep cut, but can't seem to get it to cut through like the actual part does.  I would like to be able to cut through the solid model just like a machinist would cut through with an end mill.  Meaning, always perpendicualr to the curved surface.
      I just can't seem to come up with the proper method to git er done.
      Help?
      attached file is v2010.  Thanks in advance.
      Carter
