Just tried downloading edrawings publisher (professional) 15 day trial version for ProE. Everything seems to work OK (can publish easm. files, view them, move parts, use the dynamic cross section tool)...only problem is we CANNOT MEASURE. The tool is grayed out.
We are using ProE wildfire 2.0. Been trying to fix this for two days. Does anybody know what is wrong? Is it because the Pro E is older version? Or does the trial version of publisher not enable measuring?
David
When publishing as eDrawing you don't get the choice to change any settings.
In SW it is best to use "Save As" instead of "Publish as eDrawing"
When you choose Save As eDdrawing you will be able to click options and there you can enable the choice "Okay to measure this eDrawings file". This is how it works in SW at least.
I think you should have some similar Options in ProE or in the eDrawings publisher for ProE... (See attached picture for the Save As dialogue in eDrawings)
/Sebastian
