Hello, I am looking for a way to wrap a flat plate 1/64" thick with a lip on each end end around a 8" cylinder with a slot in it for both ends of the cover to fit in. I am looking for a way to make sure that the lip will be designed properly to fit into the slot without interference. Is this a feature Solidworks can handle?
Use this file. Modify the lip dimension and the angle and see at what point you have interference. That will give you the slot size.
BTW, you have to click rebuild when you change anything, so the length of the straight side equation to be recalculated.
