I've gone through the tutorials, and watched a few videos, but I haven't seen an example similar to mine yet.
The way I figure it, you could either create the solid and convert to sheet metal, or create the end shapes and use a lofted bend, but that doesn't get me the curve I need to the transition.
I've attached the file, so if you all would be so kind, please offer your suggestions.
Hi Rick,
Unfortunately you cannot produce this as a sheetmetal part. In the real world of sheetmetal you would be required to stretch the material as the material is being push/bent in 2 different directions. From memory I did make something like this many years ago as an apprentice the old way (scriber and layout on sheet) in the factory. I also think that there may have been a few segments to make it.
Cheers
Damian
