Hi all,
When i editing a sketch it shows a msg in Repair Sketch tool " Description of problem: A small enitity. Is it intentional? " What that means? i can not rebuild sketch coz of this error plz help.
Tnx
Samantha.
Hi all,
Tnx
Samantha.
Repair Sketch highlights these errors and provides error descriptions:
- Sketch entity gaps or overlaps smaller than the maximum gap value specified in Repair Sketch
Note: Gaps or overlaps larger than that value are considered intentional.- Any point shared by three or more entities
in your case, you have too big value for the gap and hence the issue. Reduce the value to a very minimum (closer to zero) and then try.
Does it highlight any entity? If yes then try deleting that entity and check.
