Is it possible to lock a configuration from ever changing?
Ill give a simple example. I have a board, this board has different cutouts, of varying sizes and locations. Therefore I have different configurations, with cuts suppressed/unsuppressed. The location and size dims modified for the ones that are turned on.
Once I have it like I need, I want that configuration locked. It seems everytime I make a new configuration. Sometime, somewhere, somehow I forget to check the "this configuration only" box. Then I have to go through all the configs, see which ones are AFU and fix them. As the file grows, this becomes impractical. Any ideas?
Can a configuration of a part or assembly be locked so it cannot be edited?
This is currently a limitation in the software.
This limitation has been reported to SolidWorks development team as SPR# 266538
Maybe someone has another solution for this problem?
