How would you recommend I adjust the background image independently of the environment or lighting on the part/assembly? I attempted to make images in PS and add them in but I wonder what others have found to provide the best control ?
Thank you,
Jonathan
The method I use..........Save your model as an image with no background and then composite your rendered image and a background in PS. Then each will be on different layers and you can control them independently. There are others was but this is probably the easiest.
