Hello everyone, I want to project a sketch (Image.1) on a curved surface which I after would be able to extrude on that surface.
The example of the result is shown in attached image (Image.2) which was made by a sketch path line and after that I did a swept cut. But I think the technique of projecting the sketch will be much easier.
Thanks in advance.
Hi Greg,
You have a number of choices: you can use:
Experiment with each of them and check out online help to determine which is best suited for what you're trying to accomplish.
Regards
Mark
