Hi, all;
This might be simple questions...as I am beginner....
Would you advise and comment how I can do 1/2 or 1/4 model simulation?
Do I need to generate 1/2 or 1/4 model at the beginning? Or if I can cut or put the symmetric plan if I have already whole model?
Is it done by putting symmetric plane in step of giving constraint?....it seems asking where is the symmetric plane...how I can generate the symmetric plane in the model if I need? I could insert split line for mesh control...is it similar way?
Below is the simplified model with two thin parts assembled....how I can have the symetric plane to perform1/2 or 1/4 model simulation? how I can put or insert symmetric planes which I think that it needs to panetrate below model to cut 1/2 or 1/4 through two parts assembled?
Or, is there any site or docs...I can learn this basic?
Any input will be appreicated.
Cheol
You need to model the part as 1/2 or 1/4 depending on the symmetry. You can also achieve it by doing cut extrude and then use the faces for applying symmetry in the simulation.
