Flow Simulation 2010, SP4.0 API trouble
Question asked by Adam Vaccaro on Aug 5, 2010
I'd like to use VBA code to create boundary conditions in Flow Sim 2010 to save time.  I'm using Window 7 64 bit with the 2010 64 bit Solidworks.
I’ve installed the Flow Simulation API SDK 2010 x64 file that came with the software, but cannot get the example file 'C:\Program Files\SolidWorks Corp\SolidWorks Flow Simulation\api sdk 2010\vb_sample\api_sample.xls' to run correctly.  I get the error message “Compile Error:  Can’t find project or library”.  I see in the Flow Simulation API Help that to run VBA code on a x64 machine you need to install the x32 API SDK.  Is that my problem?  If so, I’m not sure where to find the appropriate installer...
Has anyone successfully interfaced with Flow Sim 2010 x64 using VBA?  Any ad vice on how to get this up and running?
Adam
