How to make assembly,its parts and its drawings read only in quicker way.
OR
Can we protect assembly, its parts and its drawings with password
OR
Follow these three steps
1. All the referenced parts will open as 'Read only'. After this if you open an assembly file, all the referenced part models will be read only (Though you can get write access by RMB).
2. While opening the file you can select to open it as 'Read only'
3. Even after opening the file with full access, you can make it 'Read only'
For these you do not need PDM.
We have our SW files stored on a network location, and only one user has access to move the SW files into the folder on the network. Everyone can copy files from this folder, but again, only one user can copy files into this location.
Select them all in the windows explorer, right click and select properties and then check the read only option.
No you can't set password to them.
