Test specifications for dynamic analysis
Question asked by 1-FKI4X8 on Aug 4, 2010
Latest reply on Aug 9, 2010 by 1-FKI4X8
Hi all,
I am pretty new to dynamic analysis, eventhough i have been using SWX simulation for quite some time now. Pls help me understand these specifications and the procedure that needs to be followed in SolidWorks simulation
Vibration Resistance:
The equipment should be capable of trouble free operations under the influence of propeller vibrations at the frequencies up to 5 Hz with an amplitude of 1.0 mm and the frequencies 20 to 30 Hz with an acceleration of 1 G.
freqency 5-33 Hz, +/- 0.16 mm constant displacement Duration, 2 Hrs
Vibration Proof (at 1.0 g):
Frequency 5-10 Hz, +/- 1.0 mm
Frequency 10-20 Hz, +/- 0.63 mm
Frequency 20-25 Hz, +/- 0.40 mm
Frequency 25-30 Hz, +/- 0.28 mm
Frequency 30-33 Hz, +/- 0.23 mm
Sweep rate 1 octave/minute tested for 3 axes. Duration 15 minutes/axis.
pls let me know the procedure to be followed to carry out this analysis.thanks
