So I have been using a from-to list to import routing data, but when I do it ends up looking like the attached pictures. Everything is coming in correctly, the only problem is the extra stuff. Has anyone else encountered this problem and figured it out? Thanks
Ok I figured it out, when I made the cable library I assumed the dimension for wire diameter was in mm, while in reality it was in meters, hence really large wire diameters.
