I want to do a tee using a welded stub rather than using a tee fitting. ie. The branch tee will be cut and welded into the through tee.
Both legs of the tee are the same diameter and in this case are 150 mm. The branch tee is not perpendicular to through tee. It remains in the same plane but is angled at about 30 degreed from the perpendicular.
branch tee
____/____ through tee
Derek,
The through pipe does not have a split point. A pipe penetrtion willl not work with a split point. But to make the penetration happen you do have to define the parameters of the branch route. I just used a flange to be expedient.It should work from you reducer as well.
After you do this, then right click the common point and select penetrate and it will trim the branch pipe and cut the through pipe. You can hide either the through pipe or the branch pipe to inspect the cuts. They will not be 90 degrees, but the shape of the cut can be printed to scale for the shop. They do make CNC machines to do this, but your guys in the shop should be able to bevel as necessary aw well.
