Assembly structure
Discussion created by Guest on Sep 23, 2006
You're stuck with the arrangement routing gives you. You can mate fittings and connectors, but not the routing assembly. You can't add configurations to the routing assembly (and have them work) You can't have a seperate part for each wire (or partnumber) and you can't modify the features in the route-part itself because solidworks will wipe them out when it rebuilds.
About the only re-usable component (besides the connectors) is the From-To list.
