1 Reply Latest reply on Jul 28, 2010 2:12 AM by Deepak Gupta
    How to save a drawing to pdf using a macro with the current File Name?
    RITESH BANKAPUR
      I want to use a macro for converting a Drawing file (.slddrw) to a PDF rather than using the process of File->SaveAs->.PDF
      Following is the coding for the macro which obviously outputs the file as PDF with the name RWT-ANCIL107. How can I change it so it takes the name of the current drawing file.
      Thanks for your help
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      boolstatus = Part.Extension.SelectByID2("Sheet1", "SHEET", 0.08896809136181, 0.2385039130435, 0, False, 0, Nothing, 0)
      Part.ClearSelection2 True
      longstatus = Part.SaveAs3("C:\Documents and Settings\rbankapur\Desktop\RWT-ANCIL107.PDF", 0, 0)
