JCJason Chambers27/07/2010
One of our desingers is having a problem adding Center Marks on drawings with Ordinate Dimensions.  I've since recreated the problem on my own machine.
If the following steps are followed the error occurs:
1. Add ordinate dimensions to a drawing with a hole pattern
     a. Zero line is the edge of the solid and subsequent dimensions are to hole edge
2. Add a center mark to a dimensioned hole
3. Add a center mark to a non-dimensioned hole
4. Add a center mark to a dimensioned hole
     a. Dimension lines moves
If the following steps are followed no error occurs:
2. Add center marks to all dimensioned holes first
3. Add center marks to all non-dimensioned holes
     a. Dimension lines stay put
This only started after updrading to SW2010 SP4.0 from SW2009 SP4.1.  The designer uses Vista x64 and I use Win7 x32.
What is causing this and how can we prevent it?
