Didn't see any related topics when I did a search on this, so I figured it was time to ask...
I have a part that has 3 different configurations. They are all the same size and have the same bend lines, just have different locations for some punches (each punch is a seperate feature for easy suppression within the configurations). My problem is with the drawings and the flat patterns. I only have one flat pattern for the default config. How do I create multiple flat patterns for each configuration? (I am using one drawing file with multiple sheets, each sheet is a different configuration.)
Thank you,
Chris
Under each config, create a Derived Configuration, and then unsupress that configurations FlatPattern1 feature.
