Strange vault behavior
Discussion created by Guest on Oct 17, 2006
You might want to try cleaning out your local directory. Sometimes the files you have are old because you changed the revision on the way in and it's simply noticing that it wasn't saved at that revision locally.
Otherwise, sounds like a VAR issue.
Good Luck,
Patrick Moody
Senior Designer/CAD Administrator
Winchester Electronics
Dell Precision M70 1.86 Pentium M, 2GB RAM, Quadro FX Go1400
