I have inherited a part file that for some reason it unnecessarily has two bodies in a cutlist when the part is in no way a weldment type of part. Is there a way to get rid of the cutlist and go back to just a solid bodies folder? Maybe it really doesn't matter, but know others will be confused with this issue.
Best,
Brian
SW2010 SP4.0
W7 x64
Hello Brian,
You can delete the 'weldment' icon, this will remove the main cutlist icon and display the Solidbodies folder.
You can then delete the cutlist folders or, you can delete the cutlist folders first then the weldment icon. This puts the file back to a standard multibody part.
You can't delete a cutlist folder if it contains a sheetmetal body (not when I tried it), a dialogue box pops up telling you of the problem.
Roy.
