Hi
I am not able to link blank size in my BOM. some time I may have to change sheet thickness or material or profile. Is there any way to link sheetmetal part to it's properties like thickenss,material,blank size
Hi
Thanks Tony.
I was after sheet metal parts in which we make a basic profile then we add bends/hem/miter. Is there any way to generate blank size automatically on drawing or BOM.
See attached sample
When you say blank size, do you mean the LENGTH and WIDTH of the material you need to create the part?
Ya. It is length width and thickness.
It may be of any shape or profile.
Part is built in top down assembly. Assembly contains more than 60 pats.
When I make assembly drawing, I should show each and every component size without making additional part drawings or adding any lines on part.
Ex: when we make weldment drawing, we get weldment size, length, Angle1,Angle2........
Hi Dattatraya,
You can do this using Indented BOM type. See the image attached. All the cut list properties (for you Bounding box length & width) calculated in bounding box are available to be used in BOM columns. Insert the columns in the BOM & link them to custom properties.
Regards,
Swapnil.
You can use fold and unfold tools and adding sketch between those to show width and lenght of your part. You can see the idea at:
http://www.spn-technologies.fi/swf/SPN-Properties-Flat.htm
Just look at the feature tree and see what it contains and you can pretty much do this manually. (video downloading is currently slow)
Try this
