I am asking to find out if anyone knows how to setup a gui visual record of contact points between two objects. Attached, is a simulation done using Motion Works when it was a SW add-in. I'm not so concerned with the reaction force vectors as I am with the contact mapping/tracing.
Hi Chuck,
That's an interesting animation. I know that the contact locations are generated by the solver, but I don't know in the current API if they are exposed, but if they are, it would be possible to write a little macro to generate little spheres at the points of contact. Plotting the points is actually the best way to track contact as is it incredibly complex to create meaningful trace curves from contact results when there are multiple points of contact between bodies).
Shrikant may have better insight into this, but I will take a look to see if the API has the information available.
Cheers,
Ian
