Let's say we have assemblies with some sub-assemblies. Often is hard to select one subassembly, because usually only parts of it are selected.
And in a 3D contact this is pretty messy, a lot of contacts being ignored. Or sometimes a lot of 3D contacts needs to be defined.
Is there a way to make a subassembly to fully integrate its parts and if one piece of it is clicked to select the whole thing and to "behave" in a 3D contact?
To cope with the problem I have saved the needed sub-assemblies as parts, but perhaps there's a better way.
So, what do you do in this situation?
Thank you!
I advise against using flexible sub assemblies in motion studies. Flexible mates applied in a sub assembly are unlikely to work in a higher assembly.
I apply flexible mates in the top assembly.
Rigid sub assemblies and multibody parts seem to be OK.
