Hi Guys,
I’m working on EPDM add-in to automatically generate Items for all files passed specific (item-creation) workflow transition. Items have to be created without the auto-update option. The idea is to ensure that each Item will reference only one file version. When the same file passes “item-creation” transition again new Item has to be created referencing the new file-version.
I’m using IEdmBatchItemGeneration2 interface, but I’m able to generate Items only with auto-update item to file reference. I thought that if I use EdmRefFlags.EdmRef_File during AddSelection2 method there wouldn’t be auto-update link, but the add-in generates an error.
Can someone help me?
Here is the rough code:
Public Sub OnCmd(ByRef poCmd As EdmCmd, ByRef ppoData As System.Array) Implements IEdmAddIn5.OnCmd
'This routine is called when a hook triggers the add-in.
On Error GoTo ErrHand
runcode:
Dim index, last As Object
Dim VersionCounter As Integer
Dim Value As Object
Dim LoginName As Object
Dim TransitionName, FileName, StateName, WorkflowName, FolderPath, Message As String
Dim GenerateItems As Boolean = False
index = LBound(ppoData)
last = UBound(ppoData)
Dim vault As EdmLib.EdmVault5
vault = poCmd.mpoVault
Dim Transition As EdmLib.IEdmTransition5
Dim State As EdmLib.IEdmState6
Dim Workflow As IEdmWorkflow6
Dim file As EdmLib.IEdmFile5
Dim folder As EdmLib.IEdmFolder5
Message = "The following files have changed state:" & vbLf
'create the item generation utility
Dim batch As IEdmBatchItemGeneration2
batch = vault.CreateUtility(EdmUtility.EdmUtil_BatchItemGeneration)
'Process the files that are changing state.
While index <= last
'Get transiton object
Transition = vault.GetObject(EdmObjectType.EdmObject_Transition, ppoData(index).mlObjectID3)
'Get state object
State = vault.GetObject(EdmObjectType.EdmObject_State, ppoData(index).mlLongData2)
'Get workflow object
Workflow = vault.GetObject(EdmObjectType.EdmObject_Workflow, State.WorkflowID)
'Get file object
file = vault.GetObject(EdmObjectType.EdmObject_File, ppoData(index).mlObjectID1)
'Get folder object
folder = vault.GetObject(EdmObjectType.EdmObject_Folder, ppoData(index).mlObjectID2)
'Get names
TransitionName = Transition.Name
FileName = file.Name
FolderPath = folder.LocalPath
StateName = ppoData(index).mbsStrData2
WorkflowName = Workflow.Name
'check if we are at the right transition to generate items
If TransitionName = "Change" And StateName = "State 2" Then
'we are going to generate at least one item
GenerateItems = True
'Add the file to the item generation utility
Dim emptyvars() As EdmVarVal
emptyvars = Nothing
batch.AddSelection2(vault, emptyvars, "", 0, file.ID, folder.ID, "", EdmRefFlags.EdmRef_File)
'write file info into the message string (temporary "debug" command)
Message = Message & "File: " & FolderPath & "\" & FileName & ", Transition name:" & TransitionName & ", Destination state: " & StateName & ", Workflow name: " & WorkflowName & vbLf
'Build the item tree.
Dim bDoGenerate As Boolean
bDoGenerate = batch.CreateTree(0, EdmItemGenerationFlags.Eigcf_Nothing)
If bDoGenerate = False Then Exit Sub
Else
Message = "You are not in the right transition"
GoOn:
'Process next file
index = index + 1
End While
MsgBox(Message, MsgBoxStyle.Information)
If GenerateItems = False Then Exit Sub
'Generate the items
Dim retItems() As EdmGenItemInfo
retItems = Nothing
Dim bOpenExplorer As Boolean
bOpenExplorer = False
batch.GenerateItems(0, retItems, bOpenExplorer, Nothing)
'Display status
Dim msg As String
msg = "Status:" + vbLf + vbLf
Dim idx As Integer
idx = LBound(retItems)
While idx <= UBound(retItems)
msg = msg + "Item name: " + retItems(idx).mbsItemName + vbLf
msg = msg + "Alternate name: " + retItems(idx).mbsItemAlternativeName + vbLf
msg = msg + "Item database ID: " + CStr(retItems(idx).mlItemID) + vbLf
msg = msg + "Creation status: " + vault.GetErrorMessage(retItems(idx).mhResult) + vbLf + vbLf
idx = idx + 1
End While
MsgBox(msg)
Exit Sub
ErrHand:
Dim ename As String
Dim edesc As String
vault.GetErrorString(Err.Number, ename, edesc)
MsgBox(ename & vbLf & edesc)
What is the error?
