I'm trying to render an assembly from SW with Photoview360. I have acheived great results, but I've now had to make changes to the original SW assembly. The problem is that when I open the assembly in P360 it shows the old file as I originally rendered it. I did use the 'save' feature in PV360 as I wanted to keep my changes... but it's ridiculous if following that I cant see model updates from Solidworks!
Thanks for any help.
PS - please dont say I have so save the assembly as a new file each time I want to update in PV360.
Found one solution: if I save the assembly out as a STEP file, then save and close the SW assembly is updated in PV360.
Just pressing rebuild or CNTRL+Q before saving didn't have the same result.
