9 Replies Latest reply on Jul 26, 2010 10:17 AM by Alin Vargatu
    How can I force dim angle leader lines to overlap? I'm sure this used to work.
    Nick Tanner
      Trying to dimension the angle of a chamfered pin, I cannot get the 90 deg angle to display next to the feature. i.e. with the leader lines crossing over at the implied intersection.
      I'm sure this used to work pre-2009.
      I can do a workaround by adding a line tangent to one angle edge and dimensioning onto that plus one edgeline
      Or by adding 3 points, one point at the implied intersection, one at the shoulder at of the chamfer and another at the opposite shoulder, then doing a 3-point angle dimension.
      But I shouldn't have to add geometry to add a simple dimension.
      Annoyingly, "Document properties > Dimensions > Angle" shows exactly what I want in the ANSI standard settings for bent leaders. Ansi angle.bmp
