Is there a setting in SWX that governs placement behavior for "first" component placement in an assembly?
When I start an assembly, the first component I drop in always gets "Fixed" - this is annoying (maybe I'm too picky ) as I am in the habit of orienting components and parts in a particular way - specifically I mate the base part's origin to the assembly's origin, with axes aligned (unless I'm using a part modeled by someone who didn't think that way, in which case I'll spend a minute mating the base part to the Assembly planes to make it right.... see that picky streak yet?).
This is kind of a "best practice" thing for me, and I've found it helps avoid issues later on - just curious if there's a setting I'm missing.
Thanks!
I have C.D.O. - it's like O.C.D. except the letters are in alphabetical order... they way they should be.
if instead of picking a point in the model space to drop the part, you just select the green check mark, SW will place the part as you desire (origins and planes aligned) but it will still fix the part rather than mate it. so th esoftware will meet you half-way at least.
Jeremy
