I have simple labels I want to apply to a panel. I want to show the orientation of the labels, so they need to be visible in drawings, and in assemblies that use the parts. I started looking into decals and photoworks, but I understand this is going away. I am looking for an alternative to extruding text (performance hog)
The information should reside in the SW file, so it can be seen by others, needs to be compatible with EPDM
As I understand it, the best approach is to create a jpg of the label, read into photoworks and create a decal, save the information with th eSW file.
The trouble I have is not all users see the same thing after I have gone through this excersise
Also if photoworks is going away, why would I bother learning....
so whats the best thing for labels these days?
I'd use decals. Users using newer versions of SW 2009 and up should see them correctly. They say PW is going away but no one has said decals are going away.
You could try using sketch pictures. They may work but only show in drawings in the 2010 version.
