I have been trying to figure out how SolidWorks would dimension the highlighted dimension so it would be parallel with the edge of the plate I am drawing. I figure I can add construction lines where necessary and dimension from those but that seems a little awkward. I have read there is an align to edge function available with a right click on the dimension but unless I'm missing something I don't see it. I'm on S10 sp 2.1. Any ideas? Thanks.
An alternative to the construction geometry you mentioned, is to place a Centre Mark on the hole, orient it to the correct angle and then add the dimension to a 'leg' of the centre mark.
