How to force system to have always cut list properties aways same eaven for old profiles
I did assign new property value length (lbs.) but always length appears in my cut list proprties then I have always go and change it then i need to add and link it to material
How can I save template to have it always same
Any hint?
You need to modify your weldment profile library. For each library file (.SLDLFP) you need to go to File>Properties and make sure the fields you want are there. These properties will then transfer to the cut list properties of that profile when you add it to a part. (Length, Angle1, and Angle2 don't need to be there- those are added automatically. But if you want Weight or Mass to always be one of your properties, you should add it in the library file's File>Properties, even though there the weight will evaluate to 0.00 there obviously.)
