socket weld and threaded fittings
Discussion created by Guest on Jul 11, 2006
As it turns out, there is an error with the Sw library part for the threaded 90 elbow. The sketch for arc radius is not correct in most of the configs for this part. I went into each one and corrected the radius. Now the pipe segments connect properly.
Still wondering about socket weld fittings. I guess if I modify the threaded library for socket weld it should work. Any feedback on this???
Steve
