I lost my hard drive and could only recover the assembly file and cannot open the assembly due to the fact that all the other parts is "missing". I can open this assembly file in E-drawings showing all the detail of the model. So it seems to me that the assembly file has more detail in it as just a jpg picture of the assembly. All that I need is a parasolid file or any other format of this assembly file so that I can import it again in solidworks and perform a simulation study on it. I don't need any "intelligence" anymore on the geometry. Is there any way that I can get such a file from the assembly file.
Bennie
I hate to be the bearer of bad news on a Monday but if you cannot recover the part files then you are out of luck and will not see anything when you open the assembly. The ability to view the assembly in edrawings is due to the XML graphic data that is stored in the assembly, it has no correlation to the issue of the missing part files. When you open the assembly it most likely will give you an error message saying it cannot locate the files and give you a choice to locate them or ignore them. Then it will open up blank and all your components will be suppresed.
I am sorry this happened to you.
