could anyone of you help me regarding how to call a perticular configuration in BOM............
I'm using configurations at assembly level, and when I insert the BOM in drawing it is showing all the configurations.
How can i call that perticular configuration into BOM which is active at the assembly level.
for ex: let's say I've config-A, B, C at assy level. now lets say I'm in config-A & I want the Bom to show only config-A in the drawings. when I toggle between the configurations at the assembly level I want the same changes to be in BOM, instead of setting the BOM manually.
Hi
First of all there is an option on drawings from Tools->Options->Document Properties->Detailing->Tables - Restrict top level... (see attached image)
If that option is checked when you insert a BOM it will contain only one configuration. You can change the configuration listed, in BOM properties.
