Does Solidworks has a tolerance analysis tool that you can check tolerance stack-up within an assembly. Currently I'm using Vis VSA (3D tolerance Tool) to do this but I was wondering if Solidworks has this feature built in.
Kris.
Kris.
Hi Kris,
We do have this capability in SolidWorks Premium and it is called TolAnalyst.
It is listed as the first item here:
http://www.solidworks.com/sw/products/fea-design-analysis-software.htm
and the information in our help system about it is here:
Your local reseller may be able to give you a demo of it if you do not have SolidWorks Premium.
Jim
Kris,
You picked the "correct" forum to ask this question, but you might want to ask in General as well. I asked in this forum about other tolerance analysis programs and basically got no response. I asked in General and got a couple of helpful responses.
I hadn't seen Vis VSA. How well does it work for you? Any comparison to SigmundWorks from Varatech or CETOL from Sigmetrix?
Jerry Steiger
Hi Jerry,
Thanks for the suggestion. I am not familiar with either SignundWorks or Cetol. I used Vis VSA for 3D tolerance modelling. Basically you import a JT file from any software package and you would use this to create features to be used in your analysis. VisVsa is mostly used for tolerance analysis within assemblies. You do not have to have models to start as you can create features to represent your model. Vis VSA works well but you have to be using it continually to keep up to date. I've also used SDI tools to do 2D tolerance analysis. This is an excel based program. You can download a free trial at SDI tools website.
Kris.
Hi Kris,
http://help.solidworks.com/2010/English/SolidWorks/tolanalyst/LegacyHelp/TolAnalyst/topics/TolAnalyst_Overview.htm
Jim
