We are developing a program that will automate our design process using design tables and a program we are developing in-house using VB6. The idea is you input all required mechanical information into our program and this program will dump all necessary information into each part/assemblies design table and give you your models.
My problem is when the program is opening one of the large sub-assemblies i get this error: "The Server Threw an Exception". The program then locks up and will only allow you to shut it down. I have looked over and over my code and I cannot find a solution to this problem. Has anyone else experienced this issue? Anyone have any idea's what could be causing this issue? Or possible solutions?
The code used to dump the information into the design tables has worked for a few years now thru a vba spreadsheet program. Now we are developing a standalone program that will be more robust and allow for even more automation.
If you need any more information, let me know.
Any help is appreciated.
-Shawn T.
