Hopefully someone here can fix my issue.
The PDMWorkgroup file folder (local view) is extremely slow.
First:
Solidworks 2010 SP0
XP Pro
On my workstation the refresh of my local file folder, both through Solidworks and Solidworks Explorer, a refresh of my local file folder is very slow.
In fact, any operation that requires a "look" at my local file folder is very slow. If browsing the vault, if seems fairly fast.
If i perform functions (rename or delete) via windows explorer in the local file folder, it is fast.
My laptop which is configured exactly the same as workstation is very fast in all regards, and it is looking at the same Vault.
The workstation was completely rebuilt 2 weeks ago, and was fast originally then slowed.
The workstation was defragged this morning, no change in performance.
If i do a reboot, the refresh is fast once, then slows rapidly.
Makes no difference if there are 2 files or more files in the local file folder, still very slow, but it is alot slower with the more file present.
Thanks in advance
Al
How many files do you have in your local working folder? I would guess that a lot of files that PDMWorks has to check to the vault might slow the refresh down. That would also explain operations in Win Explorer moving quickly.
If you shut down SolidWorks, restart it, does the refresh start fast and slow down over time?
