2 Replies Latest reply on Jul 8, 2010 11:38 AM by Anthony Botting
    simulation
    Alex Hongayo
      Good Day!
      I have an inquiry regarding the simulation, from the scenario: given are the thickness (t), width (b), length (l) & (k) for deflection.
      Q1. Can simulation determine the force?
      Q2. where to find the SN curve value for Be Cu? to load in solidworks library.
      Thanks a lot!
        • Re: simulation
          Vio Vivio
          With COSMOSXPRESS, you can define a force and see the displacement. And then tune the force to produce you desired K.
          Perhaps COMOSworks can do better, but I haven't played with it.
          The SN curve for sure you'll find in a book about different materials
          • Re: simulation
            Anthony Botting
            Hi Alex. Yes. In SolidWorks Premium (which includes Simulation, static analysis), you can define a non-zero displacement on the component using "Advanced Fixtures" command. Run. Next, list reaction forces on the entity with the non-zero displacement, so you can calculate K.
            For S/N curves for that particular material, you will likely need to locate a test facility who would love to sell you that data.
            Hope that helps.
            Tony
