I like to make a part like this staircase.
How do I create the perforated holes?
Robin
Robin
Hi Bram,
Have you check the embossed tools?
In Design Library/Forming Tools/ Embosses.
You may have to adapt/create one to suit your requirments but its a good starting point.
Michael
Edit
Lightning fingers Deepak strikes again
If you have 2 configs one with the embosses suppress then you should be able to flatten it.
Bram,
Sometimes, it's easier to find a supplier and purchase the materials you seek. For a custom fabricator, or job shop to try and duplicate what can be mass produced often can add needless expense to the project.
There are several large companies that make thousands of designs for the tread plate you wish to make. One example:
http://www.gratingpacific.com/metal_safety_gratings/metal_safety_gratings.html
McNichols is another that comes to mind.
I can't open your attachment.
Rob
