Hello first time posting here.
I have a question about mating. I have started a porject desiging a V8 motor. I am tring to mate the pushrod to the rocker arm, as well mating the intake valve stem to the rocker arm as well. I am having issues with what type of mate i would use as well keeping them moveable.
I have attached some pictures of the rocher arm , pushrod, and valve stem. So far all the moving part rotate correctly IE: Crack, cam, pistons, lifters, pushrods.
Raymond,
Welcome!
I would expect that you would use a tangent mate. I made a quick example of this (see attached). If this is oversimplified then I'd suggest that you zip and upload an assembly for us to take a look at.
