I have an assembly which is using several M3 x 20 cap head screws. I cannot use Toolbox to insert another screw the same, I get the error:
You can see in the browser that the part is already used in the assembly. I can copy the part in the assembly but I cannot now use this part in another assembly.
The Toolbox is installed 'stand-alone' on this machine. I have seen this before and I can get round it by copying but i am losing the use of parts in the Toolbox.
Any ideas?
Can you check if the toolbox part is referring to correct location (as it seems to be referring to a different location as per error pic)
