We are using SW 2010 and PDMW 2010. For our revision scheme, we just use the Primary and Secondary revision levels, using the Secondary level for "version" tracking. In the drawing's title/revision block, I only want to show the current Primary revision level, but not the Secondary level. In our drawing format, I have the current part/assembly revision "automatically" show up in the title block when the part/assembly is added to the drawing format. However, it shows the entire Primary.Secondary revision. Is there a way to either truncate the Revision property shown (remove the Secondary level), or is there a property to use in the drawing format that will only show the Primary level?
Thank you
We had to deal with this issue too.
What we wound up doing was tying the revision property as served up by PDMWorks to a seperate custom property from the revision property that shows in the titleblock.
We use the automatic revision incrementing in the revision block so there isn't any extra overhead.
this works for us because I revision level is tied to our ECO process so we have multiple indicators in other documentation of what the current revision of the drawing needs to be.
