Even with the 3 GB switch enabled?
I have noticed that my system only reports 3 GB but my VAR said that my 32 bit system will use 4 but only report 3.
Note: This is separate from the amount of VIRTUAL memory your system can use. Virtual RAM or "swap-file" space is pretty open-ended. Set it as large as you need. My understanding is that XP will set-aside/use a separate block for each app you run. With the /3GB switch enabled, you'll get a 3072 block for each SW session you run.
To tease you, you'll find references on the web for a /PAE switch to use a "36-bit" address block, but 32-bitXP does not qualify... Windows Server 2003 32-bit can use more thru the 36-bit PAE "spoof", but to un-block the bottleneck at your desktop you'll have to go to 64-bit XP & SW.
Anyone/everyone: please feel free to correct me if I've mistated any of this.
T.Harvey
Dell 390
Intel C2D-Extreme 2.93Ghz
4GB RAM
(2) 80GB SATA HD (1 set-aside for swap-file)
Quadro FX 3500 (256mb ram)
Windows XP Pro
SW 2006 SP4.1 32-bit
