When I modeled a solid ring with cross section 250mm horizontal x 500 vertical simulation refused to treat it as Beam with a message telling me "it has in valid neutral axis, while when I rotated the section 500mm horizontal x 250mm vertical simulation can treat it as a beam.
Is there any explain for that ?
did you do that as weldment wats thickness and length of beam
