I am in the market for an entirely new entry-level-or-better computer to run SW 2010 on Win 7 64bit. I have built my own in the past, and can easily do so again if it's called for.
The work I have to do is occasional and modest, rather than every day with complex drawings.
What are the most recent recommendations about the graphics card? It seems as though nVidia and STI each has its advocates. The forums contain concerns about compatibility issues with the nVidia cards and SW 2008. Are those concerns now alleviated? Did nVidia fix things, or did the transition to SW 2010 do the job?
If someone has recommendations for specs and/or mfr/model re the motherboard, cpu, graphics card, memory and even display, I would enjoy and appreciate the input.
Grazi.
Mel, I think if you search this forum, you'll find some posts relating to this problem with the nVidia cards. Until two years ago when I built my first system, I'd always had nVidia cards in my older machines. My home-built system has an ATI FireGL V5600 (over two years old) and it works great with extremely complex geometry and assemblies up to nearly 1,000 parts (don't have any larger assemblies to test higher numbers with).
I'm running Windows 7 (x64) and the drivers seem to work just fine for v2009 and v2010. The splash screen for v2009 (when opening SW) sometimes blacks out or contains lots of noise, but the viewport while actually working on things has always been fine. (v2009 isn't "supported" for Windows 7.)
Check some online locations with tests/benchmarks for more technical detail--places like cadalyst.com and tomshardware.com often test and publish reviews of various new stuff as it is released.
