I'm trying to work with an Excel based BOM.
I have a drawing which references to an assembly (CAB0001) which contains custom properties like project, assyid, own_item_id etc.
Assembly consists of parts (ABC0012 and ABC0013) which contain custom properties as well like manufacturer_id, own_item_id ...
Now when I add excel based BOM using template with columns defined containing custom properties, it works for all the included parts, but there's no line
describing the assembly.
How can I include custom properties from the assembly (like assyid CAB0001 ) into the bom, so the exported bom can be recognized as describing that specific assembly?
Under Bill of Material Properties (right click properties)...select the following option...
Hope this helps
