Go to the feature tree. right click on the part name at the very top, then click on the four colored sphere. The first item in the drop box is the part color, click on that.
Then the appearance tab should open. dig down in the tree for Appearances>Metal>Aluminum>Aluminum Treadplate. Double click. Your part now looks like treadplate.
You do have to have realview turned on to see this. That is done by going to the heads-up display (the transparent toolbar at the top of the model viewing area), and selecting the one on the far right. That will drop down with a few options, the first one should be to toggle RealView on or off. It needs to be on.
Yes this is easily done. Just go to the appearance tab and click on the mapping tab. Here you change the size to your needs on the size/orientation area.
Add an appearance out of the aluminuim folder.
